Inventor Forum
My Punch Tool is not punching
2 REPLIES 2
toon.sol
267 Views, 2 Replies
Hello everybody,
I need some help. I need a very straight forward punch tool that makes a 6 sided hole with an adjustable width.
(Yes it is to trap a bolt head)
I watched some vid's on youtube and thought is was very straight forward. But when i try it doesn't work.
When I apply it to my part it does find the points and shows the sketch but after that it doesn't make the holes.
I have to punch a lot of those holes, would be nice to get this working.
Thanks Toon
Tags (1)
2 REPLIES 2
JDMather
in reply to: toon.sol
When I tried your tool it worked fine.
What happens after you Finish (even though it doesn't place the holes as you expect?
Do you get an error?
Can you Attached a file with the failed Punch features showing in the part browser?
toon.sol
in reply to: JDMather
Hello JD,
This morning when I openen the model I was working on I was surprissed to see all the 6 sided holes in place. It must have been some thing with updating. Inventor is sometimes lagging with updating the model.
I will try it a bit more now. Thanks for trying.
Toon
