Is there a possibility to input multiple values in a single parts list propertie?
For example, in custom properties i can input <OD>x<t> outer diameter times wall thickness.
But is there an option to do this directly in the parts list?
I can go into every single part and add an extra parameter and use that one in the parts list.
But i want to create a standard parts list combining these propertie for me.
kind regards.
Geert
Solved by jtylerbc. Go to Solution.
Hi Geert,
If I understood your request correctly, it should be doable in Parameters dialog. You just need to make a given parameter multi-value (right-click on the parameter value in Parameters dialog -> click Make Multi-Value. You will be prompted to enter more values associated with the parameter. Is this what you are looking for?
Many thanks!
I think @johnsonshiue has misunderstood what you're asking for. No formulas can be entered in a Parts List - it must be done as a property of the parts, as you already described. However, if your issue with this method is the labor of going in and doing this many times on individual parts, there may be a shortcut for you.
If this is a part that you have a special template file for, you can also set up the custom property and formula in the template .ipt file to help with the creation of future parts.
Now that all of your parts have the custom iProperty, you can add that property to a parts list and save it as a style, if desired. If you don't already know how to do that, post back and I will walk you through those steps as well.
I guess you could use iLogic as well with a Form-Fill table
Yhank you,
For now this is the quickest solution.
using a template file is indeed also an option, but foor the current project everything is already drawn.
but with this option i can quickly turn the current project in the template project 🙂
big thanks!
