Inventor Forum
Multiple Surface Area Measuremnt
9 REPLIES 9
Message 1 of 10
charles
1593 Views, 9 Replies
charles
I've got a component that has around 250 faces and i need to measure the total surface area of just the internal faces (around 100).  Is there any easy way of doing this?
I've tried the 'Add to Accumulated Value' method but you can only do a couple of faces at a time and it's very easy to loose track of what faces you've already done.
Is there no way of just selecting 100 or so faces and inventor adds the surfaces up?
Or is there a way to merge faces together easily to create 1 complex face and then i can measure that?
I've got to repeat this process for around 50 parts.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: charles
JDMather
Can you Attach one of those 50 parts here?
Message 3 of 10
charles
in reply to: JDMather
charles
Unfortunately i can't for confidentiality because it's a production part for work.
Message 4 of 10
JDMather
JDMather
Can you make up a dummy file and Attach that?  (That is exactly what I am doing at the moment - just though you would save me some time.)
Message 5 of 10
charles
charles
Attached is a redundant part but it's similar to parts i'm trying to measure.
Everything internally needs to be measured (threads etc.)
Message 6 of 10
JDMather
JDMather
Before I create a video - just to confirm - you want area, not volume.
Never mind, I'll do both.  What version of Inventor did you say you are using?
Message 7 of 10
charles
charles
Yes, internal surface area is all i'm interested in at the moment, i'm currently using Inventor professional 2019
Message 8 of 10
JDMather
JDMather
There is a sliver in your thread that I assume was unintentional.
Zoom in HereZoom in Here
Message 9 of 10
imajar
imajar
This is one method of doing it (see attached part) - by closing off the ends, then create a new body that fully encases the part, subtracting the two, then delete the outer void.  Then you can just look at proprieties to get the surface area.
If the part is simpler, you could boundary patch the ends, delete the outer faces, and restitch.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Aaron Jarrett, PE
LinkedIn
Life is Good.
Message 10 of 10
JDMather
JDMather
I used a slightly different technique than @imajar .
You will have to subtract the area of the Boundary Patch caps if you don't want those.
This can also be done with essentially the same technique using a Derived Component that does not create any geometry in the original part file.  (Don't need to Copy Body if using Derived Component.) (Or you could simply drag the Red EoP marker up to hide the additional features, or delete them.)  Personally, I would use the Derived Component technique.
Note that you can also get the internal volume.
