Multiple parametric cutout using rectangular pattern or...
Still at the beginning of my inventor career. I'm trying to solve the following problem for days now... I thought it's simple 😞
I want to create a drawer.
The size should be defined parametrically.
The parts of the drawer should be linked with teeths like on the image but rectangular to keep it easy (no idea what's the correct word).
The number of teeths has to be updated when the size of drawer is changed.
I attach a drawing of the bottom plate. How do I fullfill the following requirements:
1. First cutout is in a corner
2. Cutout width is fx:B_Zinken
3. Cutout depth is fx:T_Zinken
4. Depth of drawer is fx:L
5. Changing depth of drawer has to update the cutouts
I don't want to create the rectangular pattern in 2D since it breaks the parametric approch.
When I start in the corner of the plate I have no possibility to select the body of the cutout - so I tried to use surfaces with no success.
Thank you guys!!!
Sorry, forgot to save 😞
Part updated... (Edit post was not possible anymore)
salariua
Not sure I understand; is it like this? Check attachment.
I would limit the stepping of the L dimension in the form to a 20 mm increment otherwise it's option 1 attached..
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
That looks perfect. I'm so curious but have no time today.I'll look tomorrow in your approach - I might have a question 🙂
This will be the accepted solution!!!
By looking at your solution I was able to rebuild your solution from scratch
Thanks again. Learnd alot looking at you solution.
When I have finished the drawer, I post an update. Maybe useful for someone else...
salariua
Do come back with the results, let us see your work.
Adrian S.
blog.ads-sol.com
