Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Multiple joint does not work?
Robert_Benjamins
Robert_Benjamins
Hello All,
Last week we migrated to Inventor 2019.4 (from 2018)
Today I noticed that the joint-command stops working after making 1 joint.
In the Screencast you can see the effect.
Is it a bug or am I doing something wrong?
Kind regards,
Robert Benjamins
Inventor 2026
JDMather
Can you try linking the Screencast (I get an error, are you sure it was finished compiling).
Robert_Benjamins
A link to the screencast:
https://autode.sk/2OcHQgP
Inventor 2026
johnsonshiue
Hi! The behavior does not look right to me. Are you using a 3D Connexion device? Have you updated the driver?
Many thanks!
Software Test Engineer
Robert_Benjamins
Thank you for the advice. I had an old driver for my 3D-mouse. It is now on the 10.6.0-version.
But that didn't solve the problem.
The problem only occurs when I change the type of joint from rigid to rotational.
When I leave the type of joint on the default, it works as aspected.
Kind regards,
Robert Benjamins
Inventor 2026
johnsonshiue
Hi Robert,
I can reproduce it on 2019.4 and 2020.1 and older releases also. This is an excellent catch. I will work with the project team to see if this is a known issue.
Many thanks!
