Multi-item selection (shift-click) & Change size with content center
elid
elid
Recently we've had a few projects that require two different materials of the "same" part from content center.
Is there a way to shift-click + Change size on all the ferrules I'd like to change of X size in 316L, to 304?
Replace all does not work because I want to keep some of X size in 316L.
Shift-clicking and replacing from content center also results in only one ferrule being changed, or every ferrule in the assembly. Not the 5 or however many I had selected.
Maybe we need a "Replace all Selected" button? Or do I just have some settings messed up?
Thanks!
johnsonshiue
Hi! Unfortunately, this workflow does not exist.
Many thanks!
Software Test Engineer
