For transforming a body, In 3D Model tab > Modify > Move Bodies Only Free Drag option is available other options namely Move Along Ray, Rotate are not available.
Solved by JDMather. Go to Solution.
Solved by gmwi. Go to Solution.
Rotate is there - in the Dropdown.
To define a ray, use Direct Edit instead...
