Mold base: create failed
This widget could not be displayed.
Hi guys, I´ve been working on a project to creat an injection mold for propellers.
The problem is that I don´t know why I can´t add the mold base, please help me and thaks!
I´ve tried with different types of molds, but the problem still there.
Check the screen for more details, please.
Replies (21)
MingweiGao
What's your Inventor version? Inventor 2020?
Is this problem occurred for any molded part? You may place a simple box into Mold and then place mold base to see whether you can place mold base successfully or not.
Steven
Steven Gao
Quality Assurance Engineer
JDMather
Can you zip and Attach your assembly here?
First thing I notice is that there is an issue indicated for your Core/Cavity.
Did you not see that?
JDMather
I´ve been working with Inventor 2018,  however I tried with Inventor 2017 & 2014 to  make sure the problem isn't related to the version. And also tried with differents bodies and geometries, but the problem still there for every case. Do you have an idea what could be the problem? Thank you so much!
-Osvaldo
Yes Sir I noticed it, it was difficult to make the cavity and core because the geometry of the propeller it´s a little complitcated, I accepted te proposed solution by Inventor because it´s better than the manual.
I tried with the version 2017 and the issue indicated for the core and cavity didn´t appear, but the problem for the base mold still there, so I think the problem with the mold base isn´t realted to the core and cavity.
Do you hou have an idea what could be the problem? Thank you so much!
-Osvaldo
Yes, Sir.
And thank you so much for your support.
The same mistake for the most simple body, I have no idea what could the problem.
WHolzwarth
I've only looked at the prop mold, but the core-cavity splitting needs improvement.
The blue spots are signals for mold undercuts.
Walter Holzwarth
JDMather
I do not own a rar extractor - I use only Windows OS zip.
I would need to see complete folder - including the *.ipj project file.
Ok Sir.
I appreciate your help.
Yes Sir.I'm conscious that core and cavity need to be improve, but the problem of the mold base still there for all kind of bodies and geometries, I've tried with a simple box and it didn't work.moldecuadrado.png
JDMather
1. Your zip file does not contain any Inventor part files (*.ipt)?
2. iProperties indicates that you have not installed Updates for 2018.
3. Your Project file (*.ipj) does not indicate active link to Mold libraries?
Ok Sir,  I´ve already checked observation 1 & 3, I tried to update my version but I couldn't, I add the zip.
Thanks.
JDMather
Can you post screenshot similar to the image that I posted above that shows your Libraries>In Use.
I think there might be a difference viewing your *.ipj file on my screen vs what you would see on your screen.
JDMather
Also,
https://knowledge.autodesk.com/support/inventor/downloads/caas/downloads/content/mold-design-content...
http://download.autodesk.com/us/support/files/inventorpro_vault_2018_molddesigncontentlibraries/Inve...
Edit:
Well, now I see your image - so I think you have the metric library.
I will have to do some testing tomorrow.
WHolzwarth
Hmm. IGS or STP files are no real help in this matter.
Try this:
- Do a Pack&Go with the Inventor files of the Mold assembly, without Design Data and Templates
- Zip it and upload it here
Walter Holzwarth
Yes Sir. Thanks!
Hi Sir, It could be a problem related to the libraries?
