Modify the Inventor Tabs
ccoomes
ccoomes
Does anyone know if it is possible to change the information that is displayed by Inventor in the highlighted areas in the image attached?
We are using vault with auto filename creation, which means that the part number will be different to the filename.
This is something that is very simply changed in solid edge and hope this can be done in inventor as well.
johnsonshiue
Hi! I don't believe so. The tab shows the file name and the name has to be unique on a per file basis.
Many thanks!
Software Test Engineer
