Modify a constraint based on a formula applied to value of another constraint
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am attempting to model a 3 stage telescopic assembly. The middle stage moves simultaneously with the third stage but at half speed/distance. Is there a way to modify a constraint based on a formula applied to another constraint. For example Constraint 1 is applied to the third telescopic stage and is a +/- constraint from 0" to 100" relative to a fixed reference surface. Constraint 2 would then be applied to the second telescopic stage and would be (present value of constraint 1)/2 relative to the reference surface. Clicking and dragging the third stage would then result in the second stage moving at half speed/distance. Ideally I want to do this in the model itself, not an animation, so I can drag around as the design is evolving. Is there a way to do this, or any other ideas?
Dan
