modelling text for 3D print
Ranjith.Dutta
Ranjith.Dutta
Can any one help me with the text style in inventor as per the sample text shown in the image.
JDMather
@Ranjith.Dutta
I would simply model the geometry.
EdvinTailwind
Just play around with Extrude (with Taper also), Offset, Chamfer etc to get various effects. Using different Bodies to easily set the colors/appearance of front and back sections.
(If you know which font was used you don't even have to sketch the shapes. Just use Text in a sketch.)
Ranjith.Dutta
Helo EdvinTailwind,
Thanks for your time!
That's one of the idea to think about, takes time though.
I thought the quickest option will be a existing  font where you can just type any text to get the required effect.
"There are many fonts available online that are similar to the sample shown above. I was just wondering if something like this is already available in Inventor."
kacper.suchomski
Inventor supports Windows TrueType fonts, so if you find a font you like, you can use it.
Kacper Suchomski
EdvinTailwind
I would avoid fonts that have shadowing and contours/outline, as these are effects that you want to control, right? These attributes may also cause unexpected collisions when being extruded or modified.
Here are some suggestions:
https://fonts.google.com/specimen/Bangers?preview.text=HeLLO
https://fonts.google.com/specimen/Chewy?preview.text=HeLLO
https://fonts.google.com/specimen/Boogaloo?preview.text=HeLLO
https://fonts.google.com/specimen/Sniglet?preview.text=HeLLO
...but I'm sure you can find more:
https://fonts.google.com/?preview.text=HeLLO&preview.size=75&categoryFilters=Feeling:%2FExpressive%2...
Download the TTF, install in Windows, restart Inventor, type the text, extrude and viola! 😄
