iAssembly Table Replace modifies sub-iAssembly
rtoorman
rtoorman
I'm trying to build an iAssembly (standard sight glass connection on a pressure vessel) which is built up out of sub-iAssemblies (ball valve, gaskets, stud bolt and a sight glass, which are all released to a library/Vault).
In the table of the main-iAssembly I use the 'Table Replace' to set the correct members of the sub-iAssemblies .
But for some reason it is then required to save one of the sub-iAssembly, otherwise the members of the main-iAssembly can't be generated.
So when i do save the main/sub-iAssemblies, Vault will indicate that specific sub-iAssembly is now modified locally.
Does anybody has an idea to where to look for the issue?
With kind regards,
Remco Toorman
johnsonshiue
Hi! When you are building an iAssembly, I suggest you check out all related files (iAssembly factory/member files and iPart factory/member files). It is because when iAssembly member needs to be updated, Inventor deletes the old member file and create a new one. Vault could be confused by this operation. It is better keeping all files editable. Finish authoring and generate all member files. Then check them back in.
Many thanks!
Software Test Engineer
