Modeling - Pipe on 45deg against pipe
marius.andersen3RVB4
Situation
Two pipes welded together at typ. 45deg.
I need to project this curve to center-plane
It is not possible to project this.
I also need a horizontal workplane tangent to lowest point of curve.
And most important thing... the features must update while changing dimensions and angle.
Believe me...
I have tried mostly everything i can come up with.
If we start thinking 3D-sketch...
I have a feeling that new projections are created when dimensions are changed.
The projection functions in 3D-sketch is faulty.
I have 20 years of expreience in Inventor, so believe this is a hard one to crack.
I can give more information on request.
Replies (8)
Sila0658
I managed to do it this way, and the curve updates perfectly to changes.
Sila0658
Next you can create a line that's has a horizontal constraint and a tangent constraint to the bottom side of the curve. Then make a horizontal plane from the line.
CCarreiras
HI!
Here's an idea... exploring multisolid (you didn't refer if you are in assembly or part context).
CCarreiras
A.Acheson
Are you using this projected geometry to cut the pipe end afterwards and need a paper flatpattern? If so I suggest a different approach. Use sheetmetal part, set diameter of run/branch. Use contour roll on branch. Split contour roll. Unfold branch pipe to flat pattern.
Regards
Alan
IgorMir
Frankly - I don't see the problem. To create the model requires a small extra step, that's it. Unless I am missing something. Here is a file in IV2020 format.
Cheers,
Igor.
Web: www.meqc.com.au
cadman777
The first question that comes to mind is:
What kind of parts are you making?
Are you using ContentCenter parts?
Are you making these from scratch using basic Inventor tools?
I ask that because you say this:
Which leads me to believe you want to make some kind of library you can reuse and change the sizes and angles.
So, depending on whether this is done in an Assembly or Part determines the method you will use.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
johnsonshiue
Hi! I think this is a bug or a limitation. The issue here is that Inventor has trouble projecting the 3D spline loop onto a plane, probably due to confusion at the start or the end. A simple workaround is to split the cylindrical face in half. More than likely the projection will work. If you don't want to modify the solid geometry, you may create a zero-offset surface (Thicken/Offset) and split the surface body in half.
Many thanks!
Software Test Engineer
Attached you can see current solution.
Model will be fine-tuned.
Part run by user-parameters.
Own iLogic form for easy access.
Thanks for your attention.
Marius
