Using Inventor 2023.2
I have a custom aluminium profile with length 2358 mm. In my assembly it's used twice, one each of the two Model States, where one has a cut-out for a door. In the iProperties Description I want to add a custom Prop: Length. Note that the length is the same for both Model States.
So, if the Description is =ALU profile NN <Length> the output string SHOULD be identical for both Model States, but yet I get the annoying *varies* in the BOM.
If I put a static ALU Profil NN 2358 mm in the description, it works as expected, but if I can avoid static descriptions that's what I prefer.
Is there some Model State setting I'm missing here, or is this just not possible?
@EdvinTailwind
Hi Edvin! What do you see in the BOM if you ungroup by Part Number? Are the descriptions identical for all of these, or do you see some subtle difference?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thanks for your reply.
I restarted Inventor a short while ago, because I had another issue with the BOM (the parts lists in the drawing wouldn't update/reflect the changes made in BOM), and now this issue is gone as well. Ie, it works as expected as any of the other single-State parts.
I know quirks in Inventor often resolves by restarting, but this time I forgot... 😄
