Model States, Parameters & iProperties
NachoShaw
Advisor Advisor
Message 1 of 14
NachoShaw
Hey
i feel like ive been here before but im going to ask, to see if anyone has a good resolution to this either natively or programatically.
Seeing as the preferred modelling route is from a base model, i have a base model. I also have a separate part that derives the base model parameters. In the separate part, i have some model states, each with a parameter named LENGTH.
Parameters
BASE MODEL: Param1 = 150, Param2 = 200, Param3 = 300
PART1: Linked Params = Param1, Param2, Param3
Part1: ModelState 1 - LENGTH = Param1
Part1: ModelState 2 - LENGTH = Param2
Part1: ModelState 3 - LENGTH = Param3
the Parameter LENGTH is set as exported so that i shown as an iProperty
when i review the iProperty per model state, i get the correct value based on the assigned value to LENGTH. For example@ ModelState2, LENGTH = 200.
When i place Part1 into an assembly 3 times, i change each instance to its respective ModelState. Then i can review each state and see the correct value assigned to Length.
When i review the assembly BOM however, it shows the name of the assigned parameter instead and NOT the value as seen in the iProperty LENGTH.
1. Why can we see the value in the iProperty but not in the BOM that reads the same iProperty?
2. How can i get the value to show instead of the Parameter name
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (13)
Message 2 of 14
BDCollett
It might depend how you are doing this, can you share an example?
I did a test based on what you said and the iProperty is coming across with a value in the BOM for each model state.
Message 3 of 14
NachoShaw
Hey
see example attached. Screenshot below explains the following
  • parameters in BM model
  • parameter assigned per model state
  • how the parameters are displayed in the assembly BOM with the component aded and each instance set to a different model state
i have set the parameter LENGTH in each ModelState as the respective parameter name to catch the value
Nacho
Message 4 of 14
NachoShaw
Hey
It seems to work if i add ilogic like this
iProperties.Value("Custom", "LENGTH") = INT_LENGTH
where INT_LENGTH is a Parameter that is not exported.
It works but i feel that autodesk should resolve this seeing as Basel Model is standard development method, deriving parts from that base model is stadnard and model states are variations of a part most likely from a base model.
Nacho
Message 5 of 14
johnsonshiue
Hi Folks,
I see the issue. This is a very interesting catch! The problem here is about how to present an exported parameter and the custom iProperty (expression vs value). The derived parameters are irrelevant here. I personally think this is a bug. It should work regardless. The BOM should show the proper value.
Let me work with the project team and see what we can do.
Many thanks!
Software Test Engineer
Message 6 of 14
johnsonshiue
Hi Natchito,
Just a update on this issue. It has been reported as INVGEN-59847. We are investigating the issue and hopefully it will be fixed soon.
Many thanks!
Message 7 of 14
NachoShaw
much appreciated Johnson,
Thanks 🙂
Nacho
Message 8 of 14
BDCollett
I just came across this issue myself, it's still there with recent patches.
A workaround seems to be that you just create a new custom iProp and have that reference the one you want. It will then bring through the parameters and not the equation.
Be nice to fix to get a fix though.
Message 9 of 14
NachoShaw
Hi
Are you saying that by creating another iProperty and getting the value from the iProperty showing the parameter name will show the correct value like
Base Model Param = Length = Param1 = 100in
Part linked Param = Length = Param1 = Param1
New iProperty = Length2 = Param1 = 100in
An established fix would be good
Nacho
Message 10 of 14
johnsonshiue
Hi Folks,
I just checked the latest status for INVGEN-59847. It has been resolved. It will be available on the coming 2022.3 update (April).
Many thanks!
Message 11 of 14
NachoShaw
Excellent news!
thanks 😃
Nacho
Message 12 of 14
BDCollett
@NachoShaw wrote:
Hi
Yes exactly! That seems to work from my tests.
You also need to push user parameters to custom iProps with iLogic if you want them to work as well.
Message 13 of 14
NachoShaw
Hey
Which is pretty much what i show in my original post 😀
Nacho
Message 14 of 14
BDCollett
@NachoShaw wrote:
Hey
Yes going around in circles a bit there 🙂
