Model from scanning surface
Hi I need help with create 3D model from surface. The surface was create from scanning data. So i begin with import .igs file with surface to the Inventor. It is windshield. My problem is: The surface has damage contour and when i create volume from this then contour is very bad. The contour of the surface should be made of radii and I don't know how to do it without deviations?
 I'm sending a folder with this STP.
Thank you for every advice.
JDMather
What version of Inventor are you using?
JDMather
See Attached 2021 file.
Hi
Thank you for your reply and usefully advice. I have Inventor Profesional 2021. It looks very good. There are some deviations from the original surface. How can I reduce deviations? By editing the folder you sent me, or is there another method?
JDMather
Edit as needed.
Only you know your true Design Intent.
