Model Dimension export as PARAMETER
heikki.jalonen
heikki.jalonen
Ref: Inventor 2023, Modelling (particularly Assy), Exporting Dimensions as parameters
Hi all.  Again, sorry.  Now - finally - we have upgraded into Inventor 2023.  Found plenty of new useful features.  Like Annotate/Dimension within the Assembly/Model space.  But: now I wonder how to utilize the given value?
How to link & use the DIM_VALUE (in blue ring) value, particularly as a part of iProperties data row?
Producing e.g. a dynamic attribute value like "Discharge pipe L= "&DIM_VALUE&" incl. Flange".
Of course, the value is updated accordingly when (not IF) inevitable changes take place.
Can't find that value anywhere, particularly not in Parameters-table. Nor other places.
Only appearing as a name under the Feature tree/Annotations, but no value can be found or picked from there. Edit-tool (directly the dimension or tree item) makes no choice.
Is it really so, that I still must make a particular sketch (in Assembly) just in order to have a place where to gather ASSEMBLED dimensions?  In a Part that's not a big deal, most of those key values are already there.  But not in assemblies.
Why asking? Because in SW this is easy: place the dimension(s), go to prop row, type text & PICK THE DIMENSION & type text etc.  And vóila, you have a dynamic prop text, reflecting the current dimension value.  In changed status too.  Can't believe Inventor doesn't support the same; just cannot find how.  Me moron...
johnsonshiue
Hi! You may promote a sketch dimension to a 3D dimension but not the other way around. The 3D dimensions are for viewing purposes.
Many thanks!
Software Test Engineer
heikki.jalonen
OK.  Thank you JSH again!  I'm gonna to continue the auxiliary sketch practice as before.  Not a very big deal, since the number of cases dynamic assembly attributes would be needed is quite limited, indeed.
