Model Corner Panel
Model Corner Panel
filippo.costantin3HZMT
Message 1 of 8
Model Corner Panel
I'm modeling a steel corner panel. I model it from a AutoCAD drawing. If I overlap the DWG and the sheet metal flat from Inventor, everything is ok, but in the center of corner I have gap between CAD and Inventor.
I attached a CAD with Inventor flat in blue, CAD drawing in white and red, and a overlay with indication of gap.
I try to place a corner joint in the model but it show me error.
Replies (7)
Message 2 of 8
Cadmanto
You need to attach the model as well.
What version are you running?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
This is the inventor part
Message 4 of 8
mcgyvr
The Autocad drawing is incorrect.
Look at where that line is in relation to the bend radius.. It shouldn't be inline with the bend line as its down further at the bend radius extent.
Message 5 of 8
Cadmanto
@mcgyvr  is correct.
But, there are settings that you can adjust to get it more of what you might possibly be looking for either in the sheet metal tab under settings or in the actual flange dialog.
Inventor Pro 2021
Best Regards,
Scott McFadden
Message 6 of 8
Can you explain what parameter should I modify in sheet metal settings?
Message 7 of 8
mcgyvr
@Cadmanto was simply stating that you can modify settings "IF" needed for all sorts of sheet metal bend relief shapes/radius,etc... That depends on exactly what you want though..
However as stated your Autocad flat pattern is wrong (or not preferred as it would cause distortion/tearing,etc... of that edge during forming) and Inventors is "better".
Message 8 of 8
Thanks, I thought that was a problem of AutoCad but I have the confirmation.
