I have created a 3D model of a gimble, with a supporting frame, an outer frame rotating about one axis, and another frame rotating withing that on another axis. When I have the assembly in the 'assemble' view, I have defined my constraints and can rotate the outer and inner frames independantly. When I switch to the 'studio' environment and try to animate the assembly, the inner frame can be animated, however the outer frame won't move.
Solved by JDMather. Go to Solution.
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Ah, I thought that might be the case, i will have to post twice to include all parts
thanks,
daniel
I would add angle constraints to control the motion (you won't be able to free drag - but will be able to operate more realistically.
Then I would Animate Constraints the angle constraints.
Better yet -
don't use the angle constraints (although your motor shafts should be connected to frames) and start learning the Environments>Dynamic Simulation.
