Modal Analysis Result Plotting
- Mute
- Permalink
- Report
I am using parametric Modal Analysis for modeling oscillators using autodesk inventor (2022) and estimating their resonant frequency for different thicknesses of wire. With the thickness controlled by a parameter L. I can get to the point of generating a Stress Analysis Report which has all the frequencies alongside the wire thicknesses L but they are not in a column beside each other and cannot be easily exported to create a plot of frequency vs thickness.
Can Inventor create plots such as these? Or is there a way to just get the results of modeling (frequency of the first mode and thickness L) in well formatted lists?
I have seen similar stuff to what I want on (https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Inve... and (https://forums.autodesk.com/t5/inventor-forum/modal-analysis-result-plots/m-p/7567980) but I cannot find the right answer anywhere.
