I hope this is the right place to ask for help regarding the modal analysis of my assebly.
I'm designing a tower that is attached to a bearing and hold upright by a spring. (See Screenshot 1, spring-end and bearing-mount are fixed.)
I have two problems:
1) I cannot figure out how to constrain the pin going through tower and mount properly. I used the normal undirected mate constrain between pin and tower. Also defined it as a pin in the modal analysis. Contacts are set to on, but during modal analysis the parts are split up into components and the tower seems to ignore the pin. (See Screenshot 2) I can avoid that by adding manual spring contacts, but they have a big impact on the Modal Frequencies depending on the spring contact strength. How can I constrain pin, tower and mount so they are regarded as a normal bearing, without adding springs in the modal analysis?
2) Gravity does not seem to affect the eigenfrequencies, even with added point mass on top of the tower. According to my analytical formulas it should have an effect. Even applying a vertical point force on the tower top does not have an impact on the modal frequencies. (Setup see Screenshot 3) Does Inventor ignore external forces when it comes to mode analysis or am I doing something wrong?
Hope somebody here has some ideas to help me find my mistakes.
Calvin
