Hello!
I am trying to rip one joint of the miter bend without any success.
I made this joint as a Part and then converted it to the Sheet Metal. But by some reason hte rip command fails to be executed.
Would you someone help me with this issue please?
Sergey
Hello!
Sergey
Solved by mdavis22569. Go to Solution.
Try changing the order. If I do the rip followed by the chamfer it worked for me
Thank you very much, sir.
Your suggestion worked perfectly well.
Sergey
Sergey
