Missing the Symbol selection in Inventor 2025 Annotate tab
DMOTS1
DMOTS1
I need to add a centerline to this motor but the symbol selection is missing from the annotate tab. Any ideas on why it's not there?
CCarreiras
Hi!
Your annotate tab in 2025 is similar to 2024 (and previous), i don't think is missing something... unless you have add an extra custom group in annotations tab in previous versions.
If it is the case you can adjust your current UI based in previous versions. Go to tools tab and select Migrate Settings.
Meanwhile, If you wanna had an work axis, go to the main tab and select the axis from Work features group.
CCarreiras
DMOTS1
