Feature Control Frames within Text Editor for notes Inventor 2017
Mark.ValentiGV5E9
Mark.ValentiGV5E9
I'd like to incorporate FCF's within the Text Editor notes in our drawings. Would this be able to be accomplished with iLogic? Other solutions/suggestions welcomenotes with FCF.jpg
johnsonshiue
Hi! If something cannot be done manually, it is less likely doable in iLogic.
Many thanks!
Software Test Engineer
2202890YUA9M
Hello  @johnsonshiue,
Could you please clarify if it’s possible to manually add Feature Control Frames within a Text in Inventor? I’ve been trying to include some general notes above my title block so they can be reused across multiple drawings, but I haven’t found a solution in the forum. Is there a workaround for this?
Thank you in advance for your time and assistance!
CGBenner
@2202890YUA9M
Hello and welcome to the forum.
As @johnsonshiue mentioned in his earlier reply, there might be a way to do this with some sort of programming solution.  There is currently no way to do this inside of the Text editor.  To accomplish this manually, you would have to place the text and then add the FCF near it manually from the Symbols palette.
If you would like to ask about possible programming solutions, you could post your full question in the Inventor Programming forum, for the experts there to have a look at.  Good luck.
Chris Benner
johnsonshiue
Hi! I don't believe it is doable. Those GD&T symbols cannot be inserted to the Text Editor.
Many thanks!
2202890YUA9M
Thank you for both replies!
I will then check the Inventor Programming forum.
