I have a multi-body part created by an employee no longer at the company. when I open it up and try to modify the sketches there are no dimensions or constraints on any of the sketches, which leaves me no way to edit the model.
Solved by JacobAE65F. Go to Solution.
You don't see these?
The planes are offset to split the body.
Hi Jacob,
The file was created in Inventor 2023 and last saved in Inventor 2024. If you are trying to open it in 2023, you will only get the body geometry. You need to open it in 2024 or later releases to edit it.
Many thanks!
I can see those dimensions, the issue turned out to be the method in which it was modeled.
