Inventor Forum
Missing Assembly Options when Importing Step File
9 REPLIES 9
Message 1 of 10
b-parsons
590 Views, 9 Replies
Hello, Long time Revit user, new to inventor (just using it to create families from .STEP files recieved from clients).
I am trying to import a STEP file as an assembly so I can Simplify it and Export it to a Revit family, but it appears to be inserting it as a part I think. I followed the same workflow with a STEP file that I had work correctly and compared the import options, and it is missing the drop down box for Assembly Options.
Am I missing a step or is there something I need to do to the STEP file before I try the import? It has been a few months since I have had to do this so I do not 100% remember if I am skipping a step.
This picture below is the one that works:
The picture below is the one that is not working properly:
Thanks in advance for the help!
9 REPLIES 9
Message 2 of 10
blandb
in reply to: b-parsons
I wonder if the second one is just a surface model?
Autodesk Certified Professional
Message 3 of 10
Gabriel_Watson
Perhaps it lacks multiple bodies, compared to another which can be split into several layers.
Message 4 of 10
b-parsons
in reply to: blandb
Is there anything that I can do to Un-Surfacize it? I need to be able to export it to Revit but the option is Greyed out and the BIM Environment button doesnt work.
Message 5 of 10
b-parsons
in reply to: Gabriel_Watson
I am not 100% sure as to what this means, is there something I can do to i guess rectify it?
Message 6 of 10
Frederick_Law
It means your STEP contain only 1 solid body or 1 part.
So 1 part is not an assembly.
Message 7 of 10
Gabriel_Watson
Probably only import it as a single part, split the solid into multiple, then use Make Components to generate multiple files.
Message 8 of 10
CCarreiras
Some STEP files are imported as Multisolid.
You can turn this multi solid into an assembly.
Go to MANGE and select Make Component
CCarreiras
Message 9 of 10
b-parsons
This did it for me! Thanks a bunch! Importing it then making it a component works - I did not know that was a feature (new to Inventor)
Message 10 of 10
b-parsons
in reply to: CCarreiras
Ah thanks for showing me where that was! That solved my issue - I got the Revit family in the end!
