Missing Add Joint Button in Dynamic Simulation
cullitok
cullitok
When I enter the dynamic simulation enviroment the add joint button does not appear at the top. I've tried changing setting and doing a clean install they both did not work.
admaiora
Do you mean the Insert Joint botton?
Have yoy tried this?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
TheCADWhisperer
@cullitok wrote:
.... I've tried changing setting and doing a clean install they both did not work.
Ask questions first, then make changes.
Q1. Post screen shot of what you see.
cullitok
This is what I see when I enter dynamic simulation.
Thanks for the help
JDMather
Do you have MS Excel installed on this machine?
Does Inventor Studio work on this machine?
Most of your panels on the DS ribbon are missing.
Right click on the panel that you do show and select Show Panels.
Post screen capture similar to this image.
cullitok
The show panels fixed it. Thank you
