Missing 2018 Function
ToddPig
ToddPig
We recently downgraded to Inventor 2018.
In the drawing environment, I used to be able to drill down into the feature tree, and hide a component (part, sub-assembly, ipart, etc...) and then said part would be removed from the associated drawing view.
In 2018, the "visibility" feature is grey out?
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Mark.Lancaster
@ToddPig
Most likely that view is associated to the base view..  Check this option while editing the view.
Update:
 When did you get your hands on Inventor 2019, if you recently downgraded to Inventor 2018?  Smiley Very Happy
Mark Lancaster
ToddPig
I refer to it as a "downgrade" only because of the amount of time spent re-learning the new methods to do what was done in the previous release. Instead of moving onto the what's new / what's cool in a new release, we are constantly asking "I used to be able to do this in 2017 .....?"
Inventor 2018
iParts = iHeadache
SBix26
I believe this works exactly the same as it did in 2017-- the last used setting of this control when placing a view is remembered for all future sessions until altered.  This is per user, not per template.
I don't recall now, but perhaps the initial out-of-the-box setting is opposite that of 2017; but I don't think so.  Just one of those things that needs to be attended to with each new version, and then we forget about it until the next year.
Sam B
Inventor Professional 2017.4
Vault Workgroup 2017.0.3
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
