added features after moving EOP BELOW THE FEATURE, do not automatically mirror WHEN EOP is MOVED BACK. Have to redefine/edit mirror command manually to include added feature like fillet, direct edit or anything else. Is is there a setting that include children thus allowing the mirror command capture the change in the feature browser?
Solved by SBix26. Go to Solution.
The way you describe it, the answer is no, there is no way to automatically include features in a pattern that are added above the pattern feature in the browser.
However, if your mirror/pattern is of a solid body, rather than of features, it works the way you wish-- any feature added to a patterned body before the pattern will be part of the pattern. Make sense?
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
This will work easily for you-- edit the Mirror feature, and instead of choosing the Extrusion feature, change the selection to Mirror Solids, then pick the block solid body. Now when you go back and add the fillet above the Mirror, it will be included automatically because it's part of the mirrored solid.
Then you can choose to make the mirrored block a separate solid body (New Solid), or joined to the original (Join).
Sam B
LinkedIn
