Inventor Forum
mirror part in assembly
3 REPLIES 3
410 Views, 3 Replies
Hi
I have a guard rail made as 1 part for left side of a machine which will go into a assembly file.Instead of creating a guard for the right side of the machine is there any options of creating a mirrored part of the left side guard and then saving so i have the right side guard?
I placed the left side of the guard on its own in an assembly and mirrored the part.It did created a right side guard as i would like....is there a way so that i can save the right side guard as a single part like the left side guard which would save me having to model up...there could be other ways to create so please any info would be appreciated
I am using 2013 version
Thank you
Greg
Hi
Thank you
Greg
3 REPLIES 3
JDMather
JDMather
Have you tried Mirror Components?
Can you attach your assembly here?
in reply to: JDMather
I did look at Mirrored Components but was not sure if this was correct.I did see it created a Base Model of the exact part but mirrored.Do i just rename the mirrored part?
To update any changes in the mirrored part do i just make changes to the original part and then update?
Greg R
Greg R
JDMather
JDMather
I recommend that you experiment with the various options of the Mirror Components tool until you have a feel for how it works.
Also, install the Service Packs for r2013 (iProperties show you on 2013 SP0).
