Minimum iMac configuration for Inventor ?
eric.daunay
eric.daunay
Do you know what is the minimum configuration to run Inventor on a iMac ?
I would like to buy a used iMac and its graphic hardware (AMD Radeon HD 6750M) is not on the list of certified graphic hardware.
Eric
DarrenP
system requirements are here: https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
why a MAC?
DarrenP
eric.daunay
A mac is more reliable than a PC
Inventor doesn't run a MAC OS so you still have to run Windows on our MAC
leowarren34
@eric.daunay I'd argue against Mac being more reliable but as Ryan has said you're going to have to run Bootcamp/Parallels to run Inventor on a Mac which if you're only going to run Inventor really defeats the point of getting a Mac, IMHO.
Minimum Spec would be a 6 Core I5, 8GB RAM (Preferably 16GB), and 4GB GPU which would set you back £1449.
Whereas a similarly specc'd Windows machine would set you back £800-£1000
Windows is definitely more value for money and as long as you maintain the PC and keep it updated then it will be reliable.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
