I have a basic part that the first extrusion feature appears to be corrupt. The part was made with IV 2008 (currently running 2014) and cannot accept updating the feature or rolling the EOP back to the orgin planes. you can modify the parameters via the API but when it Updates - CRASH. My concern is that I may have alot of IV 2008 data that is corrupt at some point.
Any ideas welcome.
Hello Dickerson2012,
Migrating your files from 2008 directly to 2014 can bring problems like the one you are experiencing. The recommended migration process includes migrating first to an intermediate file format (2008 > 2010 > 2014). Please read the "Migration FAQ's" in the link below:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E49FED2F-9088-488E-84E0-F7BAB4910DD7
There ia also a complete "Data Migration" section in the online help that could be useful:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FB9B4422-2348-46FA-964B-7845D9D96018
I hope this helps.
We are about to go from IV 2012 to IV 2014. We have files in the IV 2008, 2009, 2010, 2011 and 2012 formats.
I don't want to move all files up to 2012 before the migration unless I have to. What versions should I migrate to 2012 before migrating to 2014?
Steve Walton
Blair,
I take that to mean that IV 2014 will migrate 2013, 2012 and 2011 with no issues and that 2010 and earlier may or may not come in clean. Is that correct?
If so, it looks like I need to move everything from 2008, 2009, and 2010 to 2012. Should I re-install 2011 for the 2008 files?
Is the 3 previous release file migration requirement published anywhere? My reseller does not seem to believe it.
Steve Walton
I cannot confirm that this works. I find it unreasonable that a engineering firm with at a min of 1TB in project data in the form various releases of IV from V11 (NOT 2011) to 2014 would be expected to migrate all of the project data every release.
and this is made so much worse when all that data is stored in Vault.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
It is great that each file migration makes a new version in the filestore. Just what we needed to add to the daily backup filesize...
I wouldn't mind some sort of option to just migrate in place without making new versions.
Steve Walton
thats a minor issue IMO. Especially now they removed the need to create a new filestore version for metadata only changes.
Scott Moyse
The point that I was driving at was not directed at Vault. Rather legacy ( older that 3 or 4 releases ? ) project data "Invalidated" or "Corrupted" by newer versions, if that is the case. To my point, has the internal data structure really changed all that much from V11 to 2014 as not to allow a direct path of migration without data / functionality loss?
Nathaniel
Nathaniel
I understand you weren't directing it at Vault. But I was adding weight to it by stating it's worse when you are using Vault.
Scott Moyse
Nathaniel,
Sorry for the thread hijack with the Vault issues. As Scott said, Vault adds complexity to migration jobs.
The main issue for this thread is that old IV files need a way to be opened by current releases without corruption issues. If that is not posible, we need clear guidence from Autodesk about which Inventor version will open which files. This should be part of the release notes, What's New documents and help files for each version. That way users can make an informed decision about how and when to migrate files to avoid issues while balancing the storage and time requirements for migration jobs.
Could a "super migration tool" be part of subscription benifits?
Steve Walton
I have attached two pieces of data that are listed as made with 2008 and updated with 2014 ( the same as post - http://forums.autodesk.com/t5/Inventor-General/Error-and-Crash-when-making-Changes-to-Threads/td-p/4...
Exhibit-A-Crash.ipt ( CER_90216705 ) crashes inventor when you modify the parameters of the feature.
Exhibit-B-StringToLong.ipt produces a "String to Long" error message and causes IV2014 to become unstable when you modify the HoleFeatue ( See Attached Image )
If anyone can add weight to this by confirming that these produce the errors I would appreciate it.
-Nathaniel
