Inventor Forum
Metal 1400F Hot,
3 REPLIES 3
lkirit2000
350 Views, 3 Replies
Metal 1400F Hot,
Hi
I couldn't find  Metal 1400F Hot in the Material List. How I can add ?
Rgds
3 REPLIES 3
Mark.Lancaster
in reply to: lkirit2000
@lkirit2000
Assuming you are using Inventor 2013 or newer..  I would start here: http://blogs.rand.com/support/2016/06/create-a-new-material-or-appearance-and-add-it-to-an-inventor-...
Mark Lancaster
lkirit2000
in reply to: Mark.Lancaster
Hi
Thanks for your response.
I am going through the Advanced Assembly e-Portal lessions.  According to lessons it seems that METAL 1400 F Hot is as a Default in the library.
Rgds
SBix26
Metal 1400F Hot is an Appearance, not a Material, at least in the libraries provided with Inventor.  It's important to be clear about the difference between them:
  • Materials have properties such as density, strength, thermal capacity, etc., and are applied only to a solid body.
  • Appearances have properties such as color, reflectivity, transparency, texture, and are applied to faces.
Did your tutorial really ask you to change the material to something that didn't exist in the library as installed? Or was it the appearance?
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
LinkedIn
