Message 1 of 10
- Mute
- Permalink
- Report
Inventor 2022 Build 554
Mesh will not generate on this PC. Same part meshes as expected on another PC so the problem IS NOT THE PART.
When I click [Mesh View] the green bar moves about 10% and then the popup turns off and no mesh is generated.
Help page stated to check registry for HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion #\Assembly Stress Analysis, that folder does not exist.
Also said to check for a folder in the user/temp folders and that folder does not exist.
I can edit the registry as well as create files in the temp folders so it is not a permissions issue.
I ran Inventor as Admin and same problem.
What would stop Inventor from creating the files for the mesh.
