Mesh issue
Mesh issue
shaun.oneilJBP5L
Observer Observer
Mesh issue
shaun.oneilJBP5L
Observer
Observer
 I don't know what i did to put this mesh on. I can't see any of the sketches or extrusions. How do I get them back? Also, when I measure it, it says it's 660mm across, when i only make it 26mm. I know this because I printed it, and it came out at 26mm.
James_Willo
Hi, to print it I assume you made an STL file? Is the file you have above an STL that you brought in and not that actual Inventor file? STL is unitless so it sounds like you brought the STL file in as inches which also explains the 660mm.
James W
Inventor UX Designer
kacper.suchomski
Hi
Find a file with the ipt extension, not stl, in your folders. You have opened the file that you exported based on your 3D printing model.
Kacper Suchomski
