Hi All,
When I click on "Measure" it takes a long time to let me do the measurement!!! I only noticed this on Inventor 2023!
Does anyone have the same problem?
No, sorry. Mine works as quick as expected. Using build 271, v 2023.2. Which exact version do you have?
Is it only the Measure tool that's slower than usual?
Hi Ali,
I suspect you may have Detect Sketch Loop option checked, while opening an AutoCAD dwg file with lots of lines. Start an empty part. Go to Measure command -> click on the three-bar menu on the upper right corner -> uncheck "Detect Sketch Loop." After that, it should work very fast.
Many thanks!
