- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having a mildly annoying issue. When I use the measure tool and set the precision to "All Decimals" it works fine once. But when I close it and then open it to take another measurement it appears as the below image. You can see the Primary Unit, inches, went back to the document setting of 3 decimal places but the Precision is still set to All Decimals. Oddly enough, if I have Dual Units on, the dual unit (mm in this case) retains the Precision of All Decimals.
The document setting is what determines what the precision goes back to but I cannot change that setting across all documents, therefore I would like the measure tool to reflect the precision that is shown. Thank you all!
