Measure tool inaccurate and inconsistent?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using Inventor Professional 2022.2
The measure tool seems to be giving inaccurate / inconsistent results in some cases. I have not noticed this behavior in previous versions. See below example...
On a new .ipt file a work plane was created with an input of exactly 43.7 degrees from the XY plane through the Y axis. If you measure from the XY plane to the newly created plane the measurement is 43.700007251 deg. or 43.699984915 deg. or 43.700004875 deg. ? Every few times I measure plane to plane I get a different result. Nothing was modified between the measurements. There is no other geometry in the file. It is a new file with only 1 work plane added (File attached).
We often use measured angles for setting component angles in assembly fixtures and am concerned this may cause issues. For example if I measure 43.700004875 deg. and build components around that dimension then try to constrain the part that actually has an angle of 43.700000000 constraint may fail etc...
Am I doing something wrong? Is this a bug, or is this expected behavior in the new version?
