Hi there,
I am having an issue with missing icons when using the measure tool (see attached picture, the bar with the 3 icons is missing now). This is while I'm working in an assembly.
I'm using Inventor 2022.4.
I'm also using a double screen, looked for it on both screens, can't be found.
With kind regards,
Martijn Buse
Solved by martijn.buse. Go to Solution.
This window your missing can be attached or not with the measure tool.
Probably is hidden between monitors.
I would use temporarily only one monitor, find the missing window and attach it to the measure main window.
After that, i would connect the second monitor and check if it is still attached/visible.
If doesn't work, i would use Inventor Reset Utility.
Thanks for your reply. We couldn't find the window unfortunately.
I tried removing the Inventor folder in regedit and that did work.
Have a good day!
