Inventor Forum
Welcome to Autodeskโ€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
MBD-error message
3 REPLIES 3
johanna.hoog5Q647
210 Views, 3 Replies
MBD-error message
Hi, Im getting this errormessage when trying to add a GD&T position tolerance for the holes made with the command "Hole", when they have a recess or a countersink. Only got the G1/8 thread on top to work.
What can be wrong, how can I choose a reference surface? When I click on the front surface I only get a tolerance for a surface profile.
Hope someone can help me ๐Ÿ˜ƒ
3 REPLIES 3
Hi Johana,
could you, please, give us exact steps for your workflow or video with detailed steps, for better understanding. Thanks!
Martin
Thanks for answer. I would like help to put out a GD&T position tolerance for the four holes in the corners made with hole command. I can only get it to work with one part of it (the through going hole and the recess separately) not the hole feature.
Let say, that you would like to create a Tolerance Feature on 4 holes created by Hole 3 feature. In such face Tolerance Feature command recognizes Tapered Hole Parallel Axes Pattern feature, but if you click to Ok, it shows your dialog. In such case, create Datum ID, or Tolerance Feature annotation on face, where starts Hole 3 feature. Such created Tolerance Annotation, or Datum ID, will be used later as a reference feature in your workflow.
