Inventor Forum
Math help needed to calculate 3D curve
11 REPLIES 11
Message 1 of 12
jim2W82A7
547 Views, 11 Replies
jim2W82A7
The project is to design a material handling chute.  Imagine an airplane taking off.  It rises in a straight line for some distance climbing at 30 degrees.  Then it executes a 90 degree right turn of a specific radius (as viewed from above) while steadily increasing its rate of climb to 60 degrees.  After completing the turn it continues to climb in a straight line at 60 degrees for some distance.
At this stage these numbers are approximate, so I would like to develop the math to calculate points along the turn, with initial climb angle, turn radius, degrees of turn, and final climb rate as inputs.  Then I'll use these points to create a 3D interpolation spline to define the path of the curve, add the start and finish straight lines,  and create a sweep of the chute profile.
Can anyone here shed light on how to calculate the points?  Or is there an easier way to create the curve?  I might be able to manage it if I could calculate the elevation at which the turn will end and the 60 degree straight climb commence, but that has eluded me too.
Thanks for any help.
11 REPLIES 11
Message 2 of 12
jim2W82A7
in reply to: jim2W82A7
jim2W82A7
Maybe the Smooth (G2) function will give a suitable result.  The resulting turn isn't a constant radius as viewed from above, but that may not be a firm requirement.  Testing will be required to determine that.  In the mean time if anyone can calculate the points please chime in.
Thanks!
Thanks!
Message 3 of 12
blandb
blandb
Something like below?
Autodesk Certified Professional
Message 4 of 12
WHolzwarth
WHolzwarth
Something like that (2019 IPT)?
☹️ Will we ever get Inventor file attachments back here in the forums?
Walter Holzwarth
Walter Holzwarth
Message 5 of 12
blandb
in reply to: WHolzwarth
blandb
I see now, makes more sense....Had my moment there for a sec.....I agree with @WHolzwarth!
Message 6 of 12
jim2W82A7
in reply to: blandb
jim2W82A7
This doesn't appear to finish at the 6o degree up angle.  Does it?
Message 7 of 12
jim2W82A7
jim2W82A7
This looks like a solution.  I've downloaded the .zip but need to update my copy of I 2018 to use it.  I'll get back when that's finished.  Thanks!
Message 8 of 12
jim2W82A7
jim2W82A7
Ich habe Probleme mit dem Update. Können Sie diesen Teil möglicherweise im Format 2018 veröffentlichen? Vielen Dank!
Message 9 of 12
WHolzwarth
WHolzwarth
Now I'm back with 2018. I didn't test parameter changes, but it should be possible.
Anybody here, who likes zipping of Inventor files?
Walter Holzwarth
Walter Holzwarth
Message 10 of 12
blandb
blandb
For the longest time I thought I was doing something wrong, until @johnsonshiue pointed out that I needed to .zip it. Must have been a change in the website update??
Message 11 of 12
WHolzwarth
in reply to: blandb
WHolzwarth
😊 Perhaps a new productivity aspect ..
Walter Holzwarth
Walter Holzwarth
Message 12 of 12
jim2W82A7
jim2W82A7
Das hat es geschafft! Vielen Dank!
That did it! Thanks very much!
