Try switching to one of the other material libraries (at the bottom of that list)..
Does it still do it?
Hi! I guess some sort of dialog initialization was off. You may need to use Inventor Reset Utility to reset all settings back to install default. Please note that all UI customization will be reset too.
Many thanks!
Hello @ferrisb !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
