Hi
I am creating a new custom material ( PP Honey comb composite ). Later I am going to use this material for FEA .
I have got the following information. They tested for a small piece of material .
density 1.7 g/ cm3
Bending Strength - 55.71 MPa
Flexural Modulus - 4322 MPa
Maximum Load - 1510 - 1836 N
How to find other parameters ( Yield Strength, Tensile Strength, shear modulus, Youngs Modulus & Poisson ration etc) that needs to fill in when I create the material ?
Solved by jhackney1972. Go to Solution.
Hi
Thanks for your response.
I checked the matweb, there are a lot of materials and it's parameters.
This a custom material developed by our supplier. They have only limited parameters values.
I would like to know , is there any formulas to derive the rest of the parameters ?
Rgds
Rgds
