Material Library Links
ronwC2GC6
ronwC2GC6
I'm having an issue where I've created new materials but they seem to have some links to each
other that I didn't intend. What I'm doing is generating a custom Content Center with Part Numbers that are driven by size. For instance a .375-16 UNC x 1" bolt Grade 5 bolt Results in a part # BHC6UNC16G5.
That's all working well. To get the G5 I made a custom material with that name. I also made others such as G8, 8.8, 10.9 and BAl which is a Black painted aluminium rivet. My problem is that for some reason when I set the density of BAl material it also changes the density in my 8.8 material.
Is there a link somewhere that I accidentally created when the material was made?
How do I correct these issues?
Hey,
Adesk sent me a link to reply to this post
I'll be praying for you,
James
ronwC2GC6
Well thanks, see what else comes up
Frederick_Law
Look at the material physical property.
Each material has Appearance and physical property.
You need to choice or create different physical/appearance.
Usually when you copy a material, IV will make a copy of each.
If you change the name of material which I do all the time, it'll use same property as before.
ronwC2GC6
That would make sense. Except that when I do rename the physical properties it changes in the other one.
If I change the physical property name in 8.8 to 8.8 then the physical property name in Al also changes to 8.8. And also visa versa
andrewiv
Can you do a screencast and show us how you are changing the density and how it is affecting the other material?
Andrew In’t Veld
Designer / CAD Administrator
ronwC2GC6
Ahh unfortunately I figured out another solution and don't have that problem anymore.
I selected materials and appearances from the Asset Browser. This has fixed the issue and given me the correct weights.
Thanks all for your efforts
