Manipulation of drawing views in Inventor 2021 drawing environment.
Hello. Recently Upgraded from 2018 to 2021 Inventor
In 2018 I was able to edit a drawing view or a flat or formed sheet metal part that was broken horizontally
or vertically with the editing cube and direction arrows. Now, in 2021 there is no way to manipulate the view other than
the limited options in the dialog box or through the "rotate" function in the right-click menu screen. This is very cumbersome. Now, I have to unbreak the view rotate it and break it again. This is a big bug in my book. Has this already been resolved with a patch?
Also, I'm using the dark mode environment which I really like. I am having a problem though which may be related to it or not, but I am constantly losing part and assembly file tabs from my task bar which magically detach and end up all over my monitor. There is no way to reattach them or restore them. They end up covering everything when maximized. I have to drag the file to where I can see the close button, just to get it out of the way, and then reopen it. This happens a lot. I'm using windows 10. IBM
