Material applied on .ipt different from .iam
I have a query regarding the material applied on .ipt (multiple solid bodies)
1. Open Inventor > Click Inventor Icon "I" and select > New > Part
2. Click Inventor Icon "I" > iProperties > Dialog box > Click Physical Tab
3. On the Material pull down menu, select the Material that you will be needing. On this instance I use our product material which has a density of 0.220 gms.m³.
4. Now, create the multiple Solid Bodies. Save the file
5. Click Manage > Layout and select Make components and finish steps.
6. An assembly drawing will be open
7. Do step #2.
Notice the material you have created! Its not the one that you wanted.
Did my steps correct in order to have the right material on the created components that was placed on an assembly?
Can anyone please point me to the correct and proper way to do it.
Appreciate any helpp on this issue of mine.
-niels-
As far as i can see, what you're doing is correct and the result is "logical".
(i put it in quotes, because it's logical to the software.)
What happens is; you set your material in the .ipt and then choose "make components".
This derives your solids into a new assembly using your (standard) template.
The resulting file will use the default material set in that template, so not the one that you choose in your multisolid file.
(Deriving can only bring in the color override of the original file, not the material setting. see screenshot)
What you can do after you've created the assembly is go into the BOM and change the material there for all the parts.
Change one and either copy it over to the others or use the <shift>-drag method.
Hope that helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
