Inventor Forum
Mate & Angle constraint
41 REPLIES 41
Message 1 of 42
1741 Views, 41 Replies
In order to stop WASHER rotates I tried to Mate origin plane with washer plane but it didn’t work but Angle constraint stopped washer rotation. What is reason for that?
This washer already has two mate constrain to correctly position it with Conic Coupler surface.
41 REPLIES 41
Message 2 of 42
Binga
What are the references you have used?
If you put between the shaft and the washer, it is possible that the shaft can rotate.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Message 3 of 42
mdavis22569
because it may not be perfectly on the same plane height etc .. I don't have the model to say 100% ..but I'm betting:
You also already have mate constraints, so it would only want you to do the Angle, or it would consider it over-constrained/conflicting if something changed, and you'd then have to go back and delete or suppress the bad /corrupt constraints.
As you learn more and more about constraints, you'll learn what is needed where ...and why.
Mike Davis
Message 4 of 42
mcgyvr
Either you didn't pick the right "solution" option in the mate constraint or the washer/whole assembly is not perfectly centered about the origin..
Post your iam (and ipt) files if you can't figure it out..
The mate constraint "should" work assuming everything is centered about the origin planes and you picked the right solution option for the mate constraint.
Message 5 of 42
mdavis22569
When you do the mate ...
try the flush for the planes this time
Mike Davis
Message 6 of 42
mcgyvr
From what I can see you only need a single "insert" constraint to position that washer instead of 2 mate constraints..
Then if you do want to lock its rotation you can use a mate constraint from origin plane to origin plane..
Or you could use joints and only need to apply 1 joint to place and lock its rotation..
Message 7 of 42
in reply to: Binga
I do not what you mean by “references”.
Shaft is not intended to rotate. You can see the shape of the shaft. And it is grounded as well.
Message 8 of 42
in reply to: mdavis22569
In IAM file is there any way to find out “perfect”?
I tried both the MATE and FLUSH but it didn’t work.
Message 9 of 42
in reply to: mcgyvr
single "insert" constraint to position…………….
Instead of 2 mate constraints single "insert" constraint is okay. But still MATE constrain is not working to lock washer’s rotation.
I didn’t try joints because my concern is trying to find out why MATE constrain is not working.
Message 10 of 42
JDMather
Attach your assembly here and end all doubt.
Philosophical question:  Why are you learning Inventor?
If mere words and pretty pictures were all that is needed it define geometry problems, why would CAD software even be needed?
Message 11 of 42
mcgyvr
in reply to: JDMather
I'm sure its very easy to figure out why its not working..
But if you can't figure it out then as stated post your assembly and parts here..
Its a super simple reason I'm sure..
Message 12 of 42
mdavis22569
in reply to: mcgyvr
This could have been resolved by the multiple options given ...
it's a simple task that is being blown out of proportion.   Share the model, or just leave it so spin ...
You're making it harder on yourself...and over complicating things
Mike Davis
Message 13 of 42
Here is the assembly.
Message 14 of 42
I have an alternative solution. Fixing is not a problem. But I wish to know why this particular option is not working.
Message 15 of 42
JDMather
Did you use Origin Planes to Mate?
Or did you use sides of key and keyway to mate?
Are the sizes of the key and keyway identical width?
If answer is no, and you use sides to mate - will the workplanes be lined up?
Or will the sides of the part be mated against each other on one side with clearance on the other side?
Message 16 of 42
 I have attached the assembly please see whether correct.
Message 17 of 42
Curtis_Waguespack
Hi fiatnm,
I'm seeing an issue as shown in these images, but I didn't look at it much closer.
I hope this helps.
Curtis
Message 18 of 42
mdavis22569
Like I said in my 1st post ...
it's not centered/on the same planes
Mike Davis
Message 19 of 42
mdavis22569
Curtis and I both found right away you have other constraint issues causing this issue...
Mike Davis
Message 20 of 42
What could be the reasons that plane has moved?
