Mastering in i Logic
lkirit2000
Advisor Advisor
lkirit2000
Hi
I would like to learn mastering in i Logic ( try to learn deeply in i Logic).
Is the any learning materials , books or reference manual available ?
Anybody Can help me ?
Rgds
Accepted solutions (4)
Xun.Zhang
Hello @lkirit2000,
Here is a video you can refer to -
And also, here are some materials for you as well -
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
Hope it helps!
Xun
philip1009
First thing you should learn is that iLogic is based on a computer code language called Visual Basic, it doesn't function exactly the same, but it's still recommended to learn it since it will help you set up all of the logic you need.  Here's a YT playlist I've found to be very useful since it takes nice slow steps to teach every function:
https://www.youtube.com/watch?v=mM3zB3QWuv8&list=PLC601DEA22187BBF1&index=1
Keep in mind that iLogic doesn't allow you full functionality of a VBA application and doesn't allow you full access to the Inventor API, about 95% of it, pretty much all except Event functions and other advanced user interfacing is supported.  On the other hand, iLogic gives you access to a set of iLogic snippets, which you see on the left side of the iLogic rule editor, these are basically like shortcuts to the most common parts of the Inventor API (Application Programming Interface).
I also recommend you go to the Inventor Customization forum for better and faster help with iLogic/VBA/API related posts and questions.
johnsonshiue
Hi! "Mastering iLogic" is a big prhase. We do have quite a few master-level iLogic users here. But, they did not become masters by watching videos. They did it by doing. iLogic offers tremendous possibilities of customization. You can automate a lot of workflows using it. Certainly, there are limitations just like anything else. You need to start somewhere. Here is a collection of iLogic model examples by @S_May There are other good examples to learn from. Please feel free to ask any question you have.
https://forums.autodesk.com/t5/inventor-forum/collection-of-ilogic-models-for-beginners/td-p/7330801
Many thanks!
Software Test Engineer
S_May
Hi @lkirit2000
  1. ilogic-ubungsmodelle
  2. collection-of-ilogic-models-for-beginners
build a few models and they will understand. If you need help please write to me.
THX
