Thank you both for your response and advice.
It takes quite some effort to simply want to have the weight on a drawing.
Strange as the program is very clear when the weight has been manually overwritten.
Then why the difficulty, do I miss the underlying thoughts or has it just never been picked up properly?
Anyway, for normal Parts and Assemblies I think I've managed to keep the weight up to date with a few rebuild commands.
It seems to me to be stable with what I have tested, hereby the invitation to try and test it.
See two iLogic rules as an attachment, it goes without saying:
Place rule 'Update_All_Documents_Before_Save_Document' as event for 'All Document' under 'Before Save Document'.
Set rule 'Update' as External Rule so that the former rule can access it.
I have successfully tested both with and without Vault.
Criteria is, besides that the weight is displayed correctly, a saved drawing must be able to be opened and closed without being notified whether something needs to be updated.
Related to this, a drawing must be able to be edited and saved independently, without having to check out the model.
Let me know how or what.
I'm curious if there are methods where this doesn't work, Frame Generator for example?
Please let me know how or what.
See picture.
I almost forgot to mention that I checked 'Application Options-General-Update physical properties on save-Parts and Assemblies'.
Also, 'Applications Options-Save-Mass Property Update-Default Condition-Save'.
The first option allows for good testing, the second option I'm not sure exactly what it does, anyone?
