Inventor Forum
marking menu alias bug
4 REPLIES 4
m.waller
396 Views, 4 Replies
We are using inventor 2016.
I am having a marking menu General Dimension problem. When I select the Genera Dimension tool by r-click and move through the marking menu and select my line to dimension it goes to alias input after a split second, I can watch the dialog box go grey and the popup appears.
If I r-click and move to the button and click on it this does not happen and the tool behaves as it should.
Any solutions would be appreciated as this is tiresome.
4 REPLIES 4
mcgyvr
in reply to: m.waller
Have you loaded all updates/service packs for 2016?
That issue has been identified already.. Just not sure if it was fixed in SP1 or not.
http://forums.autodesk.com/t5/inventor-general-discussion/marking-menu-focus-issue/m-p/5797579#M5601...
@johnsonshiue (Maybe Johnson can look into this to see if it has been fixed)
m.waller
in reply to: mcgyvr
We have not installed any updates or service packs.
Reading in the other thread it does not sound like there is a solution as of 9/28/15.
mcgyvr
Regardless of if its fixed now or not you should always install any updates/service packs as soon as they are available.. (assuming your company doesn't have a schedule or procedure to do that already)
So do it Smiley Very Happy
m.waller
in reply to: mcgyvr
My company has not installed service packs yet, this is out of my hands.
However this problem is not fixed in the service packs as of yet 12/1/15 acording to
http://forums.autodesk.com/t5/inventor-general-discussion/marking-menu-focus-issue/m-p/5921653#M5704...
thank you for the help however
